If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
Quick question I hope. Since I have the 60 apart under the dash, can someone tell me what the original finish was for the parking brake warning light switch mounted on the shaft? Mine is pretty much all black and could use a good cleaning.
I've seen original E-Brake switch assy's in two formats. One is all black, the other is the switches' mounting hardware black and the switch body/barrel plated zinc/cad. Originals are embossed "John W Hobbs Corp, Springfield, IL" on the mounting bracket.
