I need some owners of 68s with small block to tell me what their fuel lines at the fuel pump look like, especially the larger feed line, not the small return line.
Is the line going to the pump that supplies the fuel (feed line) preformed like and "S".
I thought only the return line is "S" shaped.
What have you on your car, so I can compare to mine to determine if mine is correct or not. I just have a regular rubber fuel line a few inches long that goes from the metal fuel line on the frame to the fuel pump.
Pictures would be perfect.
Thanks in advance
Kurt
Thanks in advance
Kurt
