54 tach drive - NCRS Discussion Boards
54 tach drive
  • Ed P.
    • July 31, 2002
    • 270
    54 tach drive
    Hi
    The 54 I have been working on is coming together nicley. It runs well now and all seems to be working fine, except. The tach quit. Well it wont go above 1000 rpm and has a noise in the distributor. The cable is new and the tach works fine when driven with a drill motor. So I suspect its the drive in the distributor. I did a search and did not find any info for the 6cyl dist. Any help at this point would be great. Thanks Ed
  • Ed P.
    • July 31, 2002
    • 270
    Re: 54 tach drive
    Maybe a rebuild shop. Ed
    • Robert S.
      • July 31, 2004
      • 377
      Re: 54 tach drive
      Ed, you might give Grossmueller's a try. http://www.gccorvettes.com/?action=home They have the distributor tach gears and rebuilds. I would think they would also offer rebuilding distributors. Bob
      Bob
      • Troy P.
        • February 1, 1989
        • 1279
        Re: 54 tach drive
        Can't help you with that issue but have many other 54 parts if you need any.
