If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
Do they judge the color of the coolant ,and if they do who still makes green antifreeze ?
THANKS
JOHN
I have never personally seen coolant color judged for Top Flight Awards.
However, if you simply want green colored anitfreeze, Zerex still sells under their 5/100 Brand (5 year/100,000 miles). This is a conventional antifreeze, just like everyone used to use in their cars "back in the day". NAPA may have, or have them order it for you. The Prestone HOAT antifreeze in the yellow jug also has a greenish-golden tint.
Many (self included) prefer Zerex G-05 HOAT antifreeze for the older cars, although its color is yellow/gold.
Larry
Follow this to read about the Zerex offerings.
Go to www.farrelloil.com and under document library choose Farrell oil newsletter 3rd quarter 2006
I thought back when I was a kid all antifreeze was green .I can not believe they do not judge the color.
THANKS
JOHN
I don't know when it changed to green but I know, for sure, that it was pink for 63 and at least most of 64.
It looked red with something that made it look pearlescent that gave it a somewhat pink appearance.
I don't think coolant color is judged. But if you're to the point where you're concerned about it, then it sounds like you've got just about everything else covered and Top Flight should be no problem. I do know that the judging manual does say something about windshield washer fluid color however. You might want to check that out.
