Clem this is from a post you made many years ago.
if your manifold has the holes on both sides under the carb that supplys heat from the exhaust heat riser crossover i would plug them with the proper sized cup type expansion plugs. this will cut down on the amount of heat the carb see from the exhaust crossover. check to make sure your heat riser valve is not frozen shut. the last and best solution is to block completely the heat riser crossover in the intake manifold.
Where are some commom places that I can purchase the expansion plugs and what size?
