If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
After rebuilding and reinstalling my 427 in our '69 I have encountered an unusual to me problem. The engine starts up just fine. After running for 10 to 15 seconds it just shuts down. Any thoughts on a cause? It can be restarted too.
David #19639
Dave, are you starting up a cold engine when stalling out? does it re-start right away?has the engine spec.s been set (timing, dwell, idle mixture, idle speeds for cold start and warm engine).
David, After the car shuts off don't touch anything and get a test light to see if there is current at the + terminal of the coil. This will eliminate the ignition switch and wiring up to the coil.
Process of elimination to see if it's electrical or fuel.
Ed & Tim, Thanks for your posts. The timing, points & etc are OK. I started it up and when it died I checked the voltage at the coil terminals, 0 volts. Looks like I will be doing some electrical checks tomorrow. Thanks again.
David
With a straight forward points ignition system, the usual thing to look at for a start/stall condition is the ballast resistor. However, since it sounds like you just put everything back together, you must recheck all connections that you made in the process.
