Can someone make a recommendation of type and weight of lubrication to be used in a C1 steering gear?  What are the pros & cons to using synthetic lubrication in the gear?  Thanks
					Recommendation for steering gear lube?
 Re: Recommendation for steering gear lube?
 My understanding is that the C1 steering gear uses "gear oil", which would be any API SAE 80W-90 GL-5. "Synthetic" versions of this are usually rated 75W-90. Look at your ST-12. If it recommends Mil-L-2105 that is the same as the API spec. In fact, a few years ago the military cancelled Mil-L-2105 and now uses the API spec.
 I doubt if using the 75W-90 will make any difference in steering feel or gear life for typical vintage Corvette useage.
 IIRC the C1 steering gear is not in close proximity to the exhaust manifold as it is on C2/3 models, so the gear likely doesn't run as hot, which is why a synthetic gear oil will have little or no advantage.
 Duke- Top
 Corvette Steering of S.C. rebuilt the steering box for my 58 I filled it with gear lube and it kept leaking out the front of the box.Called them and asked if there was supposed to be a seal there , they said no and that they used a mixture of half gear lube and grease and squirted it in with an old style grease gun.Hasn't leaked since.- Top
 That may be a result of overfilling. IIRC there is a plug on the steering shaft jacket for adding gear oil. It should probably not be above this level, and I assume ST-12 has checking/filling instructions.
 Anybody with ST-12 want to tell us what is says?
 Duke- Top
 This is exactly what I am seeing as well. Checked to be sure we didn't overfill it but it still leaks out the front. This has been a habitual problem for us using 80W gear lube. Thanks for the information, we'll give it a try.- Top
 Chuck,
 For C-1 steering box (probably C-2 also) use GM "Steering Gear Lubricant" part # 1051052 Group # 8.800. Not sure if it's still available but check your local Chevy parts guy. It's heavy bodied like chassis grease and won't leak out. It turns up on e bay once in a while. RichAttached Files- Top
 The ST-12 for steering says "The steering gear is filled at the factory with a special all-season gear lubricant. Seasonal change of this lubricant is unnecessary and the housing should not be drained. The steering gear lubreicant level should be checked every 1000 miles. Whenever required, additions should be made using a lubricant which, at low temperatures, will not "channel" or cause hard steering and which will provide staisfactory lubrication under extreme summer conditions. Steering gear lubricants are marketed by many oil companies. The steering linkage should be lubricated every 1000 miles with chassis lubricant. Lubrication points and additional information on the cahssis lubricant to be used can be found in Section 0-General Information and Lubrication."
 On page 0-7, the reference to the steering gear only says "steering gear lubricant"
 Hope this helps, although they don't list specific lubes to use.
 steve- Top
 Thanks Richard. I'll try to find some.Chuck,
 For C-1 steering box (probably C-2 also) use GM "Steering Gear Lubricant" part # 1051052 Group # 8.800. Not sure if it's still available but check your local Chevy parts guy. It's heavy bodied like chassis grease and won't leak out. It turns up on e bay once in a while. Rich- Top
 Interesting! I can't recall ever seeing any commercial lubricants labeled "steering gear lubricant", but maybe back in that era there was such an animal. The lubricant description is so vague, it's not clear if it's gear oil or grease.The ST-12 for steering says "The steering gear is filled at the factory with a special all-season gear lubricant. Seasonal change of this lubricant is unnecessary and the housing should not be drained. The steering gear lubreicant level should be checked every 1000 miles. Whenever required, additions should be made using a lubricant which, at low temperatures, will not "channel" or cause hard steering and which will provide staisfactory lubrication under extreme summer conditions. Steering gear lubricants are marketed by many oil companies. The steering linkage should be lubricated every 1000 miles with chassis lubricant. Lubrication points and additional information on the cahssis lubricant to be used can be found in Section 0-General Information and Lubrication."
 steve
 Duke- Top
 Duke, we had a Kendall warehouse next to my shipyard back in the early 80's, they sold tubes of 'steering gear lube', it was a gear oil like honey consistancy. Put some in my 59 at the time.
 Dan1964 Red FI Coupe, DUNTOV '09
 Drove the 64 over 5000 miles to three Regionals and the San Jose National, one dust storm and 40 lbs of bugs!- Top
 Chuck...
 Original C1 steering gears were filled with a special steering gear lube, about the consistency of 90-weight gear oil. Due to the steering box location next to the exhaust manifold, a service letter was issued in 1958 for the dealers to use chassis grease ( same grease used for ball joints and tie rod ends)
 If you use 90-weight oil, don't add the oil to the box until it is in place, as the oil may run down the steering column shaft.
 If you use grease... GM # 12377985 63-82 steering box lube is recommended. Several supplies have sale a grease fitting (Zip is one) that replaces one of the bolts on the side cover. Pump the grease in until it comes out the top fill plug. Do not pump grease into the column...- Top
 This is correct info, GM did away with the 90 wt oil due to leakage and went to chassis grease in early 1960.Chuck...
 In that case, any NGLI #2 general purpose grease should be okay. If exhaust manifold radiated heat is an issue (like on C2/3 models), then I would recommend a "full synthetic" grease. You should be able to find a suitable product at most auto parts stores. I know both Mobil and Valvoline sell such a product.Chuck...
 Duke- Top
