If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
In the process of preparing my 1962 for painting, removing all chrome etc. Am having a tough time removing the side window glass. It can't be that difficult. What is the trick????
Ted
Hey Ted, No, it is not that difficult. You just need to remove the right parts.I remove the vertical in the middle of the door, the end rail at the back of the door, all door reveal moulding, window stops.It also helps if you loosen the bolts on the window regulator a little. You kind of just have to wiggle it back and forth and it will come out. Hope this help's, let me know if i can be of more assistance. Thanks,Steven J..............
You're exactly right, I just got back from removing the windows taking about everything off and a lot of pushing and pulling.
It doesn't seem that putting it together will be any easier.
Thanks.
Ted
Ted, the more you work with them, the easier it gets. Just to remember to have patience, take your time, and think backwards when putting them back in........
