If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
#41R 539 - Anyone know where I can get a couple of these?? Just noticed the "Tangs" have been sheared/broken off on 2 of the 3 carbs I have (don't ask why I have 3!!).
Thanks!
Ron
Hello Ron;
Probably doesn't help to state that those plastic cams fall apart over time.
Checked, don't have any available.
Did you try the vendors in the "Driveline"?
Hope this helps.
Ray
And when you get the choice to sit it out or dance I hope you dance
Nope, that's not it. Fast idle cam is on opposite side of throttle linkage. I didn't see it anywhere on the Holley site so I will call them and see if it's still available. I'm only 1-1/2 hr from St Charles so I plan to go to Bloomington in 2 weeks, may be able to find some there. It's funny that the 2 that are broken are from replacement units. The original from my carb built in Dec 1965 is still fine!!
