1960 Shifter hole size - NCRS Discussion Boards
  • Mark P.
    • May 13, 2008
    • 934
    Can someone please tell me the dimensions of an unmolested shifter hole through the fiberglass shift tunnel. The width of mine is 2 and 3/8" which looks correct and untouched. I need the length.
    Mine was enlarged and I am repairing it.
  • Bill M.
    • April 1, 1977
    • 1386
    Re: 1960 Shifter hole size
    My '59 is 3-3/4.
    • Bill B.
      • December 1, 1993
      • 192
      My 61 is 2 3/4'' wide X 3 1/2'' long I suggest depending on how many sides were modified or (cut), might throw the true dimensions off. So after proper size cut is established, I would install transmission with shifter and go through the gears including reverse checking for side clearances. Remember the shifter boot hides a multitude of sins.....
      Just my two cents....
      Bill
      1961 Black/Silver/Red Int. 283/315 FI
      power windows. Frame off 65% completed.
      1989 White/hard top/Grey Int. daily driver 167,000 miles
      "The problem with Liberalism is that eventually you run out of other people's money" Margaret Thatcher
      • Stewart A.
        • April 16, 2008
        • 1035
        3 1/2 Mark. The hole is only a smidgen smaller in length than the chrome shifter plate. The shifter plate is 3 3/4 Stewy
