69 exhaust - NCRS Discussion Boards
69 exhaust
  • Jim M.
    • February 23, 2009
    • 233
    69 exhaust
    I recently purchased a complete new exhaust system for my 69 along with new manifolds. Since the car had headers on it when I got it, I really didn't have an original system to look at when I took it out. My new exhaust pipes come with two short extentions where the pipe meets the manifold. I see where they go but my question is why? Why not just make the pipe a little longer? Any help would be appreciated.
  • Jamie F.
    • May 20, 2008
    • 337
    Re: 69 exhaust
    Jim, I'm not sure what you mean by extensions?
    There are two small pipes that go inside the flanged end of the head pipes where they attach to the manifolds, but they are not extentions, more like alignment sleeves.
    Is this what you are refering to?
      • 43271
      Re: 69 exhaust
      Jim-----
      The extensions don't actually serve to "extend" the length of the forward pipe. Their purpose is to align the forward pipes with the manifold, center and align the packing, and help shield the packing from direct contact with exhaust gasses. Some forward pipes have the extensions as integral with the forward pipes, but GM originals did not.
      • Jim M.
        • February 23, 2009
        • 233
        Re: 69 exhaust
        Jamie, alignment sleeves I guess is a better description but they do extend the length of the pipe by just a little bit. jim
        • Jim M.
          • February 23, 2009
          • 233
          Re: 69 exhaust
          Jamie, Joe, thanks for the explanation, that all makes sense now that I look at the setup more closely. Jim
          • Kenny C.
            • March 2, 2009
            • 191
            Re: 69 exhaust
            Hello
            Not that it matters to you because you already have your system but just in case others are interested. I just got a complete system for my 69 SB from Gardner Exhaust and I couldnt be happier. Everything fit PERFECTLY and looks great with proper bends and wrinkles. The set up cost a few bucks more but worth every cent.
