If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
Bill, If You Have A Holley Carb, The Nuts W/ Built In Washers Are Blk. Phos., The Tcs The Same, If You Have A Rochester Carb They Are Bolts Rather Than Studs And They Are Blk. Phos.
