Painting Original 70 PB Master Cylinder - NCRS Discussion Boards
  • Bill L.
    • February 1, 2004
    • 1403
    Well I did it once and the DOT 3 ruined it with just the slightest spill. When I painted it the first time there was absolutely no rust since it was just rebuilt.
    After the leak it now has a very little rust on the out side and just a very tiny bit on the inside.
    Should I just repaint the outside and take my chances? Should I coat with POR15 and spray the flat black before the POR15 dries?
    Should I have it disassembled and cleaned before painting?
    I will be using DOT5 when I refill the system.
    Man I hate doing things twice
    Bill
    • 11692
    Re: Painting Original 70 PB Master Cylinder
    Bill,
    I used some of the VHT caliper paint on my brake calipers this winter. One of the calipers leaked where the soft hose screws in, and 2 months later I just wiped it up with no loss of paint. I'd give it a try.
    I will never use POR 15.
    Patrick
    • Michael G.
      • March 2, 2008
      • 487
      Patrick, I'm curious. Why the dislike for Por-15?
      Mike
      • Bill L.
        • February 1, 2004
        • 1403
        Patrick,
        What do you think about painting over the very minor rust? That is the only reason I was considering POR15.
        Bill
          • 11692
          Mike
          Yes, I've used it previously.
          The short answer:
          Independent testing has shown better products. http://www.eastwoodco.com/jump.jsp?i...Y&iMainCat=688
          Yes, I know it's posted on the Eastwood site but I agree with the results. I have received this magazine for many years and saw the original article.
          It is impossible to remove - from anything. Ever.
          It's too glossy for almost any application.
          It's a poor excuse for doing something right the first time.
          But that's just my opinion.
