71 LT-1 carb stud - NCRS Discussion Boards
71 LT-1 carb stud
  • Robert S.
    • December 11, 2008
    • 122
    71 LT-1 carb stud
    Basic question: What are the correct finishes on the carb stud, nut, and washer? This is not specifically addressed in the TIMJG. No luck searching the archives either, but I did see a discussion suggesting that perhaps a separate nut and washer may have not been used for this year. Any further comments on this?
  • Edward C.
    • March 1, 1985
    • 125
    Re: 71 LT-1 carb stud
    My very origional 71 LT-1 has nut and washer and all including the stud appear to be natural finish. the nut could have been blackened but I don't think so. Ed
    • Robert S.
      • December 11, 2008
      • 122
      Ed, thanks for your reply. I have seen black phosphate and natural finish studs from the usual suppliers. Sounds like your setup is the way to go.
        • 15632
        The nut is somewhat unusual in configuration. I lost your post yesterday afternoon when I went to the desktop to post the picture of the stud and nut on my 1970. I hope I can fnd yoru post tonight.
        • Dave S.
          • August 31, 1992
          • 2930
          Robert,
          I've attached a couple of carb. photos of my 71 LT-1 5 star car. Of the 4 nuts one has the throttle cable bracket under it and another has the fuel line bracket. The other 2 go directly to the carb. base. None of the 4 have lock washers. Nuts look to be plated with zinc or cad.
          • Robert S.
            • December 11, 2008
            • 122
            Dave, good pics. Looks like a standard nut. The studs seem longer than the ones I was looking to get. Can you estimate the height about the intake manifold?
            So, one car with washers, one without.
              • 15632
              You all don't want to see my 1970 now. It will just confuse the issue.
              • Robert S.
                • December 11, 2008
                • 122
                Terry, I realize that for 70 that the nut had an integral washer. But do the length of the studs on your car appear to be the same as Dave's?
                  • 15632
                  I'll make some measurements tonight.
                  • Dave S.
                    • August 31, 1992
                    • 2930
                    Robert,
                    It's a little hard toi get an accurate measure but the nut is about 5/16" high.
                    • Robert S.
                      • December 11, 2008
                      • 122
                      Thanks, Dave. It the nut is 5/16" thick, then from your pics it looks like the stud rises about 5/8" above the nut for the right rear with the fuel line bracket. So, I would guess the total stud height projecting above the top of the carb base to be approximately 1 inch.
                      • Edward C.
                        • March 1, 1985
                        • 125
                        Just checked the AIM and it shows a stock nut and no washer.Gotta take my washer off. Ed
                        • Dave S.
                          • August 31, 1992
                          • 2930
                          Robert,
                          That looks right. I don't think any judges will be measuring but if you have around 1" to 1 1/8" you should be fine.
                          • Robert S.
                            • December 11, 2008
                            • 122
                            I also saw that in the AIM. But there must be a reason for the judging manual to specify a washer for 71.
                            • Robert S.
                              • December 11, 2008
                              • 122
                              Robert,
                              If I add in 1/2" for the carb base and 1/4" for the insulator/gasket, it looks like the total stud height above the intake manifold should be around 1 3/4".
