Can anyone tell me what the correct bolt looks like that holds the alternater brace to the drivers side exhaust manifold. The bolt I removed is indented head E, grade five with captured lock washer about 7/8" long. Looks like a battery box to frame bolt and I am not sure it's correct.
Thanks for the help, I can't wonder if this bolt should be grade eight as I removed a single WB grade eight from the intake manifold but it's the same length as the other intake bolts. All the rest of the intake bolts are grade five and headmark NAT.
The head mark of the bolt that attached the bracket to the exhaust manifold is a "M" with 3 lines (grade 5). It also has a split ring lock washer. Pete
. I was wondering how they did it at the factory. My car "M"ust be special.
