If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
My 1981 Coupe is in need of weatherstrip replacement. Has anyone worked with the aftermarket latex weatherstrips? Are there any advantages to the latex kits versus the normal rubber kits available from Corvette parts houses? Is it worth the extra money?
I am currently restoring a 1980 model and have the same question. I would like to purchase an "all inclusive" kit that has every seal. I was looking at Ecklers "Soff Seal" are these NCRS correct. Are the GM replacements still available, or should I be looking at another brand. Help needed. Thanks
