A couple of questions:
(1) What are the differences between '68 and later upper corner molding pieces (the ones the soft top pins fit into)? I've noted several comments to the effect that the '68 pieces are different. I have an original very beat up set (p/n's 3935693-LH, 3935604-RH) and a repro set (p/n's 3966601R-LH, 3966603R-RH) and except for the slot for a screw on the outside edge of the piece and the slot on the inside (toward the center of the car) of the tab that fits under the header molding, I can't discern any other obvious differences.
(2) The tabs on the front of the header molding piece are pointed straight out, essentially parallel to the ground, when the piece is on the car. Is this the correct orientation or should they be bent more downward?
(3) Should there be some sort of sealant behind the reveal molding piece? None apparent on the one I'm looking at.
Thanks!
Thanks!
