If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
Confused again! I have 1970 454 4spd. NCRS JM p.62 says choke rod clip should be "small black oxide clip that locks back on choke rod." Other sources say it should be a little "e clip." Help?
I know of no reason to doubt the JG which says both versions of the clip were used (lock back style through '70 and circular style for '71 and later). Looks to me like the circular style was a cost reduced version of the lock back clip, so it makes sense one was early the other late in terms of use...
