1971 LT-1 fan shroud - NCRS Discussion Boards
  • Robert S.
    • December 11, 2008
    • 122
    My fan shroud has a rather large rectangular chunk cut out near the bottom of the circumferential section, which I assume is not correct.
    Part number shown on it is 3956109. Need confirmation that this is the correct number to find a replacement. Thanks.
  • Paul O.
    • August 31, 1990
    • 1716
    Re: 1971 LT-1 fan shroud
    Robert that is the correct shroud check where the section is missing there should be 3 small holes that is where the extension is attached with 3 small bolts. If I remember correctly the shroud at those holes have a special nut for the bolts they are pressed in to the shroud. You can find the extension at swap meets, the Driveline, or that auction site. They are hard to find I don't have my parts book with me but someone will probably list the part # for you. Paul 18046
    • Robert S.
      • December 11, 2008
      • 122
      Thanks, Paul. I did another search and I came up with 3956118 for the extension. So I should have what I need.
      • Dave S.
        • August 31, 1992
        • 2930
        Robert,
        Here is a photo of the lower shroud on my 71 LT-1 #16798.
        • Robert S.
          • December 11, 2008
          • 122
          Dave, great photo. That looks just like mine. I had assumed that some prior owner must have chopped out the section for some reason, but must be correct. So, that's good news. Thanks.
            • 15634
            Great picture Dave. Is it my imagination or do I see a U on the heater hose? My 1970 has a U every 3 to 4.5 inches along its length.
            • Dave S.
              • August 31, 1992
              • 2930
              Terry,
              What you see is JT not U. The 71 JT heater hose is a 4 rib hose with the 2 outer ribs being thin and the 2 center ribs are thicker. I looked at my 70 LT-1 out of curiousity. The lower heater hose has not markings at all with very faint ribs and the upper heater hose has O every 8 inches or so.
                • 15634
                For many years I thought there were no marks on my heater hoses, until the upper hose burst by the AIR pump. With the hose off I can see the U marks on the underside of the hose. I don't know the pattern of the groves on mine, but since those identify the manufacturer I don't think too much about it. I can look when I get home though -- I think I have a photo of the stamp I can post too -- but I don't want to drag this thread off topic. I just wanted to compliment you on the picture.
                • Paul C.
                  • November 12, 2007
                  • 511
                  Do the shroud extension bolts go from the inside to outside of shroud (head n inside of shroud) or outside to inside (head on the outside of ther shroud)? Where are the three-prong zinc-plated T-nuts supposed to be embedded--on the outside of the shroud extension or the outside of the shroud??? Mine has them on both?? Thanks. Paul
                  • Paul O.
                    • August 31, 1990
                    • 1716
                    Paul
                    The 2 upper or on the horizontal axis the 3 prong nuts are embedded from the outside of the shroud the head of the fastener toward the fan.
                    The lower is install the on the vertical axis the 3 prong nut embedded in the extension toward the fan the fastener head toward the ground.
                    • Paul C.
                      • November 12, 2007
                      • 511
                      Thanks. Now I can proceed installing the extension. You've been a big help.
                      Paul
