If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
There is about a 1" gap between the bottom of the defroster duct and the outlet in the main horizontal airbox duct that is just below it. Is this gap normal or do I have a problem?
Standard GM design practice, to isolate the noise/vibration of the heater box from the duct and upper dash panel, which would amplify them (like a drumhead).
