Motor dyno test; assembly lube question - NCRS Discussion Boards
  • Jerry G.
    • April 1, 1985
    • 1022
    My 327 road race motor is ready to Dyno. Because i'm usning stamped steel rockers and a wet sump i've been generous with use of assembly lube( moly disulfide) I'm a little concerned that on initial run in on the dyno that all this assembly lube may clog my oil filter. Anyone had any expirience with this issue? Is it a non problem? I'm getting a little paranoid. That first start up is a little tence for me. jerry
