c2 timing moves after initial setting - NCRS Discussion Boards
    • 15661
    Re: c2 timing moves after initial setting
    If you have no evidence that this 43 year old distributor has been overhauled since it began life, I would strongly suggest...
    It's not hard and there are extensive discussions in the archives.
    • Robert B.
      • March 1, 1999
      • 43
      Duke - I agree. Its time. Thanks.
      • Tom L.
        • October 17, 2006
        • 1439
        #18
        Just a note on idle RPM. Are you using the tach in the car? Recently when changing my points and then adjusting dwell I checked the RPM using the dwell meter. It showed that the Tach in the car was 200 RPM low. If you had the idle set at 750, and you have a problem like me, your idle may be as high as 950. As a result you may be getting advance from the weights. Good luck!
        • Robert B.
          • March 1, 1999
          • 43
          #19
          Yes using another rpm source in my timing light. Good thought. I think my next step is a distributer rebuild. Thanks
          • Wayne K.
            • December 1, 1999
            • 1030
            #20
            As Duke suggested, did you confirm that the dwell wasn't changing ?
            • Robert B.
              • March 1, 1999
              • 43
              #21
              Wayne, It is next on my list. I ran out of time. I will post my findings. Thanks, Rob
