54 questions - NCRS Discussion Boards
54 questions
  • Guy M.
    • November 1, 1993
    • 500
    54 questions
    1) What is the size of the machine screw that holds the headlight bucket assembly in place? 2) Where does the felt go in the gas tank area, under the tank over the large holes??? 3) Any idea where I can get the motor mount tab thats welded on the frame? Some idiot cut it off. Thanks folks
  • Mike E.
    • February 28, 1975
    • 5138
    Re: 54 questions
    That's only 3 questions--where are the other 51?
    • Roy B.
      • February 1, 1975
      • 7044
      Re: 54 questions
      The felt goes on the raised area where the tank straps hold the tank down (TWO) , the holes stay open .The other two questions I don't know
      • Mike M.
        • May 31, 1974
        • 8389
        Re: 54 questions
        i'd fabricate the needed frame pieces and weld them in.mike
        • Guy M.
          • November 1, 1993
          • 500
          Re: 54 questions
          Thanks for taking the time, I reaiiy appreciate it, there are alot of secrets to this year model that after 20 years im still learning
          • Mike E.
            • February 28, 1975
            • 5138
            Re: 54 questions
            Guy--
            If you're talking felt, it glues to the top of the fiberglass gas tank cover, so that the top, when put down, does not have the back window scratched. If you're talking tar paper, that goes under the tank and on top of the tank underbody as a cushion beween the two.
            • Guy M.
              • November 1, 1993
              • 500
              Re: 54 questions
              Hi Mike, I know about the felt on the tank cover, this stuff is 3 1/2" wide and 1/4" thick (black felt) and there was 3 of them. Im not sure if this is factory stuff for coushining reasons or maybe some just put it in there. Was there any coushining either on the bottom or around the straps? I have read nothing that talks about this if there was anything at all. Thanks as always.
