If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
I am changing the diff oil in my 73 for the first time. Should there be an o-ring or gasket on the fill plug? It look like the oil was leaking out around the plug.
3/4" NPT tapped hole. Use some Permatex high temp thread sealant on it and you're good to go.
Update on using this product. It does seal very well but it also tends to lock the threads. I have had to use some heat to break threads loose so I no longer use it on differential plugs. I use #2 Permatex instead
