71 Holley LT-1 (4801) power valve numbers - NCRS Discussion Boards
  • Mike E.
    • February 28, 1975
    • 5139
    If anyone can help with those numbers, I'd appreciate it. I don't have a Holley book, and my parts store is primarily computerized and doesn't have a clue on this one.Thanks!
  • Paul O.
    • August 31, 1990
    • 1716
    Re: 71 Holley LT-1 (4801) power valve numbers
    Hey Mike we met each other at St. Charles Nationals really admired you LT-1. Mike the best way to select a power valve with the engine warmed up and at idle check the vacuum if it lets say 13" Hg divide that by 2 gives you 6.5" that's the power valve you need. Holley power valve numbers are the last 2 digits in the part number so like 125-165 is 6.5" PV. Hope that helps I think that a 6.5" would be correct but it's best to check your vacuum first. Paul 18046
    • Cleet H.
      • October 21, 2008
      • 29
      mike,
      i have an lt-1 (4801) in a box at home, so it would be easy to get to, the problem is i don't know what a power valve is. let me know what i'm looking for and i'll check it out when i get home.
      cleet
      • Tom L.
        • October 17, 2006
        • 1439
        The power valve is screwed into the primary meterng block. The Primary (front) bowl and metering block must be removed to get to it. It will be screwed into the side of the block opposite of the bowl. The number should be stamped into it on the diaphram side. This picture should help.
          • 43222
          Mike-----
          The power valve should be a Holley #125-85, aka GM #3852485. The GM part is discontinued.
          • Joe C.
            • August 31, 1999
            • 4598
            http://www.holley.com/data/TechServi...%20Listing.pdf
            • Mike E.
              • February 28, 1975
              • 5139
              Joe--
              Just a quick clarification, if I might ask. Is both the primary and secondary power valve a 125-85? The primary one we took out looks to be a 65. No idea if it is original or not. The Holley site is giving my computer fits--get an error message every time I hit the power valve icon.
              Thanks.
              Mike
              • Paul O.
                • August 31, 1990
                • 1716
                Mike I looked at the Holley site for you a 4801-1 lists a 128-85 for the primary and secondary power valves. As always Joe was right on the numbers. Paul 18046
                  • 43222
                  Joe--
                  Thanks.
                  Mike
                  Mike----
                  As far as I can tell, they are both the same.
                  • Joe C.
                    • August 31, 1999
                    • 4598
                    Joe--
                    Thanks.
                    Mike
                    Mike,
                    Do you have Adobe Reader installed on your computer?
                    If not, then you won't be able to read items in pdf (pagefile) format.
                    I will back up one page for you, and let you try again from there:
                    http://www.holley.com/TechService/Library.asp
                    from here, click on "Carb Numerical Listing"
                    The PV is misprinted in the listing. It reads "128-85" but all PV's have a "125" prefix, so should be "125-85".
