091 coil - NCRS Discussion Boards
091 coil
    #31
    Re: 091 coil
    Remember, the act of measuring/confirming primary and secondary winding resistance is a necessary but NOT sufficient test for coil operability.
    All you do when you measure resistance is confirm the transformer's (an ignition coil is a transformer) primary and secondary windings are intact. That tells you NOTHING about the health of the transformer's core lamination(s) which are what transfers energy from the primary to secondary windings...
    • Ted S.
      • January 1, 1998
      • 747
      #32
      Re: 091 coil
      Jack, so other than buying NOS how do you know you're not buying a piece of junk? With the price of 091s these days it could add up quickly.
      • Dave S.
        • August 31, 1992
        • 2930
        #33
        Re: 091 coil
        Ted,
        In simple terms the only way to test a coil is to put it on a running car and let it heat up to operating temperature and run it for awhile. If it performs under those circumstances then the coil is good.
        • John D.
          • December 1, 1979
          • 5507
          #34
          Re: 091 coil
          63 Shop manual. Specifications 14-5.
          091 Coil.
          Application: All (???)
          Primary Resistance-Ohms 1.02-1.13
          Secondary Resistance-Ohms 8000-10,500
          Ignition Resistor Ballast.
          Resistance-Ohms of the IR = 1.4-1.62.
          As typical the 63 shop manual has incomplete info and totally disregards the 087 coil and the D1110 BR.
          I have been reading this 091 post the whole way thru. If it were my car I wouldn't be experimenting with oils in the fried coil. I would be putting a good SR coil on the car and putting the bad one on the shelf in hopes that some day it could be properly restored.
          Temporarily I would install a nice NOS 087 or 202 which are readily available on ebay for about 125 or so and take the hit. Or a good used one. Ever see what the damage is when a coil explodes??? It's scary. My friend sent me a pic of his 57 engine compartment when an SR coil blew up. Hinckley know who I am talking about as the guy lives in his 'hood. JD
