I have a 091 that does not work properly, car starts and pops etc. Upon removing the screw and coil wire catch there is no oil inside. The bottom of the can is bugged out a bit and I remember it got hot when I tried to use it.
Is this trash or can I add oil and try over again. What type of oil is used in these coils. Any help is appreciated, If I put my ohm meter across the primary terminals the the needle deflects to no resistance. If I put ohm meter terminals from primary + or - to secondary the needle does not move. Thanks for the suggestions, Tim
Correction, If I put ohm meter from secondary to primary + or - I have approx 9500 ohms.
