72 correct thermostat outlet
  • Robert B.
    • March 1, 1999
    • 43
    I have a 1972 big block LS5. I am trying to find out the correct numbers for the thermostat outlet and if these were dated, and lastly if they are aluminum or iron. Thanks.
    • 43133
    Re: 72 correct thermostat outlet
    Robert----
    All 1972 Corvettes used thermostat housing GM #3877660 OR GM #3972128. The thermostat housings were both die cast aluminum. None had dates.
    The GM #3972128 is pictured below.
    • Robert B.
      • March 1, 1999
      • 43
      Excellent - Thank you!
