65 horn relay mounting - NCRS Discussion Boards
  • Donald S.
    • January 23, 2008
    • 183
    can some one post a pick of the horn relay mounting on a 65 BB car and also give me measurements as to the hole location .thanks Don...
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: 65 horn relay mounting
    Don -- here's the driver side rad support area of my 396, showing the horn relay mounting holes. Last (3rd) shot is of the forward side of the support before removing bolt for horn relay, taken in a mirror then reversed image digitally, to appear as if you were looking directly up at it. The outboard of the 2 holes is the threaded one --- may even be smaller that the inboard hole, which is only to insert and locate the tab on the '824' relay. In 2nd shot, I pulled back the relay to show the rad shroud bolt (caution: all bolts in these shots are non-NCRS ). Maybe that bolt's a good datum to measure from.
    Let me know if you want me to take some dimensions, or just drop by yourself to check what you need. P.S. I emailed you some eBay shots of 396 rad supports, showing these and other holes.
