C4 -1989 Lift/Adjust front end - NCRS Discussion Boards
  • Sam K.
    • April 1, 1988
    • 50
    I'd like to raise the Front end of this 1989, without installing Coil-Over's
    What process is involved... shims for Frt Spring ???Thanks for help.
  • Sam K.
    • April 1, 1988
    • 50
    Re: C4 -1989 Lift/Adjust front end
    Dave: So if I raise the end of the Front Spring, in the Pocket, this will "raise" the front end, and if I lower the Front Spring, in the Pocket, it will lower the front end.... it that Correct ???
