If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
Hello i am in need of info on convertible rear quarter trim panels. specifically the attaching screws at the bottom., does the conv. use the hex screw, then the single oval head phillips screw with carpet on top of panel. Judging manual isnt real clear about the hex screw for convvertible ? Thanks Mike
