64 rear quarters - NCRS Discussion Boards
64 rear quarters
  • Leonard W.
    • July 30, 2008
    • 9
    64 rear quarters
    Hello, I'm a new member and I'd like to know what is the correct finish and color for the back side of rear quarter panels for a 1964 coupe. Mine has two different finishes and colors and was wondering if points would be deducted because of this?
  • Dan H.
    • July 31, 1977
    • 1370
    Re: 64 rear quarters
    Hi Leonard, do you mean 2 different body colors on the back side? Maybe from a repaint or a donor fender/repair? The correct 'finish' would be, in this order: undercoat, primer, body color, blackout. This was all done when the body was still off the frame, look up blackout and under coat in the archives, lots of info there! Have a White Castle for me!
    Dan
    1964 Red FI Coupe, DUNTOV '09
    • Mike M.
      Director Region V
      • August 31, 1994
      • 1463
      Right, Dan. Good explanation of the wheel well application, I am also not clear on just which surface is being referenced.
      If the question is the inside natural Fiberglas finish, then yes, there would be deductions for anything other than the "White Glass".
      HaND
      • Wayne W.
        • April 30, 1982
        • 3605
        64s had mostly gray glass. The gray does vary. The inside areas that are not blacked out will be bare fiberglass and sandblasted near all bonding areas.
