For all C1's having a PG relay - NCRS Discussion Boards
  • Roy B.
    • February 1, 1975
    • 7044
    I get calls asking me where can they get a PG relay #904, If you can find a NOS it can cost upward of $400.00 and used ones may be bad. So I tell people to locate a Chevy (over drive relay) and modifie it by adding a jumper wire and cutting the tag off to make it look like original ,here's how=
    You hook the ground coming from the PG switch attached to the shifter to #4. The hot coming from the ignition to #3 with a jumper wire to #2,then the wire going to the starter to #1 when you turn the switch it will engage the relay only in park or neutral position.
    Some original relays have the #904 on the back side so this will fool many judges. Hope I helped some one save money!
    PS it's a good idea to carry a spare like this one , but if not connecting the key wire to the starter wire you can start the engine to get home.
  • Joe R.
    • July 31, 1994
    • 287
    Re: For all C1's having a PG relay
    Thanks for the tip Roy. I have a passenger one (NOS) and will do the mod for a spare.
    Keep 'em coming!
    Joe
    • Roy B.
      • February 1, 1975
      • 7044
      Keep 'em coming!
      Joe
      Keep 'em coming ? I'm not that good it's just when some one ask a question and if I'm lucky I might know the answer. and I'm not always right!!
      • Michael L.
        • July 31, 2005
        • 562
        Roy also told me how to "jump" my relay until I could get my switch on the trans adjusted properly, worked like a charm... I'm using a three prong model out of a Nomad, not correct number, but it works
        • Troy P.
          • February 1, 1989
          • 1279
          You lost me a bit on this one Roy. I can see what lug to cut off. But I can't figure out where the jumper wire goes. I assume it's under the sheet metal cover. Do you have a photo of the jumper in place? Which lug is #1, #2, #3 and #4?
          Also I'm curious if a 12V overdrive relay could be so modified and used safely/successfully in a 6V Vette.
          • Roy B.
            • February 1, 1975
            • 7044
            Looking at the original relay on the fire wall left lug is #1 bottom # 2 right # 3.
            #1 is from the key #2 goes to the starter # 3 comes from the PG
            The four lug #2 and # 3 you jump them using a wire # 4 comes from the PG
            The relay don't know it's a 12V or 6V it's used on both !
            If your still lost in the woods I cant help you
            • Troy P.
              • February 1, 1989
              • 1279
              I get it, the two lugs that come out the bottom need to be jumped. Now I still wonder about using a 12V relay for this 6V application. As I understand it the starter relay carries the full current to the starter and don't know the wiring in the 12V relay is heavy enough to function properly. Anyone know?
              • Troy P.
                • February 1, 1989
                • 1279
                Anyone know if 836 (voltage unknown) and 876 12V four pole relays can be similarly converted to 3 pole starter relays. Also, anyone know what the original applications were for the 876 and 836?
