64 door lock installation - NCRS Discussion Boards
  • Len P.
    • July 31, 2005
    • 12
    All,
    I am having trouble with reinstalling my door locks. Is there a top and bottom to the plate that holds the lock in place?
    I am having trouble with the lock assembly coming loose after I shut the door a few times.
    Appreciate the help.
    Len Palmer
  • Tom H.
    • December 1, 1993
    • 3440
    Re: 64 door lock installation
    You might have the clip on upside down. It is like a spring and when installed correctly should hold pretty tightly. If it feels loose when youput it on, it's on wrong.
    Tom Hendricks
    Proud Member NCRS #23758
    NCM Founding Member # 1143
    • David D.
      • January 1, 2005
      • 416
      To elaborate some on what Tom is saying.....From what I experienced on several installations, if the backing spring goes on easy to mild you have it backwards. Flip it over, cuz I found it is a bear (cub) and needs to be persuaded with some umfff.
      JMHO,
      David
      • Tom H.
        • December 1, 1993
        • 3440
        JMHO,
        David
        That's what I was trying to say !!
        Tom Hendricks
        • David D.
          • January 1, 2005
          • 416
          Tom,
          I know...I just wanted/needed to add a few comments, because the scrapes and cuss words are still fresh in my memory. *$&#@&*
          It's what my pycho-analyist calls good stress relief.....Me and a friend who worked on these both came to the conclusion that GM took these and a few other gems as their first points of assembly and then built the cars around them.
          The people who originally assembled them no doubt were laughing, thinking about the future, and folks like us and the girations and contortions we'd have to perform if we needed to fix/replace......
          I'm kidding of course, no I'm not, yes I am, no I'm not, yes I am........
          David
          • Tom H.
            • December 1, 1993
            • 3440
            Tom,
            David
            Funny how something as simple as that is so hard to descibe while typing. I hope he finds he had it in upside down and all is well now !!
            Tom Hendricks
            • Len P.
              • July 31, 2005
              • 12
              All:
              I am sure I put the plate in backwards...... Went in easy and falls out with no real effort closing the door.
              Len Palmer
                Len -
                The lock cylinder retainer is "bowed-up" when placed on a flat surface - you have to press down (hard) on that portion of the retainer to flatten it out as you push it into place so the sides of the opening go under the lugs on both sides of the lock cylinder and lock in place when the retainer is fully installed. Photo below of a typical installation.
                • Len P.
                  • July 31, 2005
                  • 12
                  John,
                  Sounds good. I know that I did not get the plate in correctly from your discussion. Appreciate the picture.
                  Len Palmer
