If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
I want to add brake fluid to my 67 but don't know what type is now in the
master cylinder. i rubbed some on a panel and it didn't remove paint.
what else can i do to identify the type.
You can take a little of the fluid out of the master cylinder and mix in a little water. silicone fluids do not mix well with water. To be sure of your result you could do the same test with your known new brake fluid. There are some other tests too, but I never remember any of em past this one.
