door latch mechanism problems - NCRS Discussion Boards
  • Keith M.
    • April 30, 1998
    • 39
    Any suggestions on interior door latch mechanism free play? The exterior works fine but I have just enough travel to release on the inside. I have adjusted the rod as much as possible but still too much free play.
  • Mike M.
    • May 31, 1974
    • 8389
    Re: door latch mechanism problems
    common problem with c-2 latches. remove the latch assembly form both doors. there is a small lever that presses on the unlatch mechanism. once you've identified the slop that accumulates on the lever over the years of opening the door from the inside, simply weld a bead on the small lever to decrease the play between the small lever and the unlatch mechanism. i believe i wrote an article years ago on this subject in the restorer. good luck,mike
    • Keith M.
      • April 30, 1998
      • 39
      Thanks Mike, I apreciate your advice.
