If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
54 pan without the step up front, is about 3/4 from steering thingy, what must come off to get the pan out of their,can pull exhaust probably low enough but what about steering stuff or anything to do with lower pulley, will pan slide out or hold up on parts in that compartment? Thanks Brad.
Brad, the pan will come off with the tie rods removed from the center arm and thew exhaust crossunder pipe swiveled down. You can then lower the rear of the pan first and it will clear (JUST BARELY!) the front.
Joe, what releases the threaded top the nuts go on to drop down thru the center arm, nuts are free but can't pull tie rod ends down, do I need to tap down with hammer or unswivel something? Thanks Brad
