Harmonic Balancer Bolts Stripped - NCRS Discussion Boards
  • Richard P.
    • July 31, 2001
    • 173
    When I tried to put the harmonic balancer pulley back on my '61, I find that one of the bolt holes is stripped, and will not tighten. How can I repair without having to replace the balancer?
  • Christopher R.
    • March 31, 1975
    • 1599
    Re: Harmonic Balancer Bolts Stripped
    1. 3/8" helicoil.
    2. Or, tap the holes to 7/16".
    • Mike M.
      • May 31, 1974
      • 8408
      helicoil it. if not familiar with helicoils, take to local auto machine shop and they can fix it. simple and inexpensive cure for your problem. good luck,mike
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11366
        Hmmmm, shouldn't all of the threaded holes be heli-coiled for proper "balance"?
          • 43288
          Richard-----
          I don't think one needs to go that far and, personally, I would not. I believe the effect on balance of the damper would be negligible when installing a heli-coil in one of the pulley bolt holes. You're replacing, essentially, an equal volume of steel with an equal volume of steel. I feel VERY confident that any effect on balance would be well within the normal factory tolerance. These things were not balanced like rotors on a jet engine.
