If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
I have reviewed the TIM&JG, Nolan's book, the AIM and the TDB to find the codes that should be on the shock stickers with no luck. Long Island sells stickers "EL" and "EM". Are these correct? Which is code is front and which is rear?
Just to confuse you, I am told that the codes are EK on the front and EM on the rear, though I have found no definitive, authoritative source to give me, or anyone else, any comfort on this.
Gordon Andrus
Houston Corvette Service, Inc.
713-896-0119
