1960 Transmission question - NCRS Discussion Boards
  • Mark P.
    • May 13, 2008
    • 951
    I have been looking for a T-10 transmission for my car. The one I located has casting stamps that are the same day or preceed my assembly by 4 days.
    Is this being judged and if so would the date being too close be a deduction ? If a deduction how many points would I lose ?
    These transmissions seem to be tricky to find.
  • William C.
    • May 31, 1975
    • 6037
    Re: 1960 Transmission question
    Typically, trans dates are not judged however an occasional Chassis judge is small enough to get under the car and look, in which case "all's fair". If you are looking at four days from the case, side cover, or tailhousing date to the final assembly date of the car, that doesn't leave much time for machining, assembly, or transportation to St Louis. Unless the price is exceedingly good, I'd keep looking.
    Bill Clupper #618
    • Steven N.
      • April 30, 2002
      • 214
      .......I'm one of those guys that judge '53-62 that can get under those chassis..............
      • Mark P.
        • May 13, 2008
        • 951
        Steven - what would be the deduction if I went with the tranny I am looking at ?
        Mark
          In cases where scoring deductions are NOT mentioned as 'guidelines' in the Judging Guide book or defined in the Judging Reference Manual, club policy is to uniformly assign 20% or the available originality points to Finish, Date, Installation, Configuration and Completeness....
          • Steven N.
            • April 30, 2002
            • 214
            Jack gave a very descriptive answer !
