My tach died lasy week on my 67 Big block. Pulled out the tach coupling today and found the driven gear is chewed up - so looks like I have no choice but to pull the dist and rebuild it (I am assuming the shaft gear is also toast - hard to see while it is installed), but I can see that the driven gear has worn well into the housing - so will add the thrust button.
Found some good posts on dist rebuilding. I am ordering parts tonight and am wondering.... is replacement of the upper and lower shaft bushings recommended as a normal item during a rebuild?
