I have a 71 and the chrome wheel trim rings look good but when up close have lots of fine scratches,swirls--probably from wiping the brake dust off with a dirty rag. Any suggestions how to remove these? Thanks Paul
How Do you Remove Scratches/swirls from Chrome Wheel Trim Rings
Re: How Do you Remove Scratches/swirls from Chrome Wheel Trim Rings
For minor dust scratches, I would probably first try my Porter Cable polisher with rubbing compound.
If that didn't get them looking nice, the next step would be a try a sewn cloth buffer wheel on my bench grinder using white rouge. This approach can be tricky if you're inexperienced...you can make them worse than they are now.- Top
Try Mequiars Tech wax 2 Advt removes MINOR scratches and swirls. Used it on my 40 4 clip rings with great results. 8.5 out 10 dreiver Quality. See close up on my 67 SS 396 switched rings out for a show.- Top
I have also observed swirl marks on new rings; if the swirls are uniform and in the same direction/angle all around the entire ring, then I agree those are probably buffing marks from the factory. They probably aren't going to come out with rubbing compound if they are buff marks.- Top
