C3 Brake Light Question (Stupid but I had to ask) - NCRS Discussion Boards
  • Jack C.
    • September 30, 1992
    • 1090
    Is it possible to have only the right side brake lights lite up when the pedal is depressed. New bulbs, turn signals work fine. Grounding looks good. I know the 68 has an interesting stop light switch. All help appreciated.
    Jack Corso
    1972 Elkhart Green LT-1 Coupe 43,200 miles
    Top Flight 1994, 2018 & 2021
  • William C.
    • May 31, 1975
    • 6037
    Re: C3 Brake Light Question (Stupid but I had to ask)
    I'd start by checking the rears when the hazard flasher is engaged, then use the wiring diagram to find common and uncommon cirtcuits and narrow the search from there.
    Bill Clupper #618
    • Jack C.
      • 1090
      Checked out the flashers and they work fine. Next, the wiring diagram.
      Jack Corso
      • Richard F.
        • May 31, 1986
        • 193
        Jack, If I had to guess, I'd say 95% of the time it's the ground on the individual back light. There have been times I would have bet money that the ground on the light housing was good, but I would have lost. Check the bulb socket too.
          • November 30, 1997
          If your turn signals work, your grounds are OK, and one brake light says the brake light switch is working. The turn signal switch controls the brake lights - make sure the connector under the steering column from the instrument panel harness to the column harness is fully seated.
          Then use the wiring diagram to check for power at the the output terminals in that connector, and that will tell you if it's in the turn signal switch (which is usually the case).
          • Jack C.
            • 1090
            Thanks for the info. I recently change the switch for the third time. The original switch where the lever was wobblie and would not cancel on one side. 2nd switch, the left rear break lights would stay on, 3rd switch defective from the supplier who will remain nameless, 4th switch, cancels fine however, the left brake lights won't light when the pedal is depressed. I'll try reseating the contact points.
            Jack Corso
            • Jack C.
              • 1090
              Reseated it this morning, it works.
              Thanks.
              Jack Corso
