Removing Build Sheet From Tank - NCRS Discussion Boards
  • Joe C.
    • August 31, 1999
    • 4598
    Should that be considered as a departure from originality.
    Yes or no
    35
    yes
    0%
    5
    no
    0%
    30
    The poll is expired.
  • Joel F.
    • April 30, 2004
    • 659
    Re: Removing Build Sheet From Tank
    But it isn't observable. Same as head casting dates, etc.
    • Tom H.
      • December 1, 1993
      • 3440
      Would I be correct in saying that some cars had no tank sheet and others had sheets from other cars.
      This combination of facts would make a tank sheet nearly impossible to judge. JMO.
      Interesting poll though.
      Tom Hendricks
      Proud Member NCRS #23758
      NCM Founding Member # 1143
      • Dick W.
        • 10483
        Non judged item in any class, so it is a moot issue. If you remove it and display it separately, you always leave a little doubt as to the creditibility of the paperwork. There is no direct link between the vehicle and the tank sticker.
        Dick Whittington
        • Warren F.
          • December 1, 1987
          • 1516
          Dick,
          That's not quite true. If you are fortunate enough to own a '71 (at a specific date of manufacture) or a '72 model. There is a correlation indeed.
          The Corvette Order Copy sheet would be an extremely important piece of factory documentation for the 1971 model. Not so important for 1972, since the VIN plate denotes the engine option of the car from the factory.
          • Stuart F.
            • August 31, 1996
            • 4676
            Aren't many of the build sheets visable w/LR tire removed? Not to read, but to at least verify that there is one and perhaps the condition could be subjectively judged as to whether it was original.
            Stu Fox
            • Patrick T.
              • September 30, 1999
              • 1286
              What I did on my '67 was drop the tank with the sticker still on it and took pictures of the tank with the sticker next to my car with the license plate, which I still have and then another with my business card. I must have taken 20 pictures to remove most if not all of the doubt. PT
              • William L.
                • December 1, 1988
                • 944
                My tank sticker was removed by the previous owner. He did take a picture of it on the tank. He then wrote a letter to Noland Adams asking about info on the tank sheet. At least I have the tank sheet and all the letters to and from Noland.
                Bill Lacy
                1998 Indy Pacecar
                • Mark K.
                  • January 1, 1983
                  • 148
                  I've decided to keep my tank sticker where it belongs - on the tank (of my 67). The tank has never been down but the sticker is easily readable. I have a ton of other documentation anyway so the tank sticker is just icing on the cake.
                  1967 L71 Silver/Black Coupe - Unrestored/Original Paint, Top Flight at 1998 Regional in Ontario, not judged since
                  1995 Red/Red ZR-1 - Top Flight back in 2010 Michigan Chapter meet
                    • 3416
                    I think the tank sticker is important, but should just be considered as part of all the documentation available for a particular car. Hopefully there's a POP, window sticker, dealer invoice, etc. for the car, too. Each piece looks better if there are other pieces to back it up.
                    • Howell J.
                      Infrequent User
                      • January 1, 2003
                      • 17
                      On my 68, the tank sticker was in fairly good shape. I removed it, cleaned it up so it was more readible, then I put it in a big Zip-Lock bag, and duct taped it (the Zip Lock bag) back on the top of the tank. I figured this is where a tank sticker needs to be and the ZipLock bag will protect it.
                      • Jeffrey G.
                        • June 30, 1986
                        • 77
                        I don't understand removing a tank sticker, then putting it in a ziploc bag duct taped to the top of the tank? If it's already in a bag, why duct tape teh bag to the tank?
                        • Howell J.
                          Infrequent User
                          • January 1, 2003
                          • 17
                          I needed to replace my old fuel tank with a new Quanta fuel tank. I removed the tank sticker from the old tank. The sticker came off OK, except the glue spot where the sticker was stuck to the old tank, did tear and resulted in a small piece of the old sticker being left behind, but all the critical information was on the sticker that was removed. I cleaned the sticker up best as I could, and then put the sticker into the zip lock bag (for protection). Then I taped the zip lock bag onto the top of my new tank and installed the new tank. The tank build sticker will not continue to ride around in my car, as before, but it'll be protected from further degradation in it's new plastic covering.
                          • Tom R.
                            • June 30, 1993
                            • 4100
                            From the posts recorded...seems there is no consensus on this topic.
                            Tom Russo
                            78 SA NCRS 5 Star Bowtie
                            78 Pace Car L82 M21
                            00 MY/TR/Conv
                            • Mark R.
                              • September 30, 1990
                              • 127
                              I agree with Alan, that while the "tank sticker" is a nice item to have, it is just one component of documentation. Especially, when the sticker is not in place on the original gas tank.
                              Once the sticker is removed from the original gas tank, I would think it should be preserved in the best manner possible and included with any other documentation and receipts related to the car's history. If the car is a highly optioned high horsepower car and the "tank sticker" is the only piece of documentation available, I would suggest having the removal of the sticker photographed and witnessed. If the owner is an NCRS member, he/she might reach out to a local chapter to offer the removal of the sticker as a tech session/clinic and obtain the confirmation of the sticker coming from the car in question. JMHO
                              Mark
