If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
the hand written date in witch the frame was pulled from inventory should be what color ??? neither the jm or nolands book makes reference to color that i saw. i have seen red is that correct ?thanks don .
