C4 Build sheet locations - NCRS Discussion Boards
  • Joe C.
    • August 31, 1999
    • 4598
    Re: C4 Build sheet locations
    Right underneath your rear differential.
    As opposed to your front differential.
      • 11644
      Yeah, but my truck as one of those.
      • Richard C.
        Infrequent User
        • August 31, 1987
        • 7
        #18
        Originally posted by Richard Capone (11910)
        Help,
        Trying to locate my original build sheet for my 1985 #1518. I have some locations to search, but don't want to tear the car apart to find nothing. Any previous knowledge or tips would be greatly aprreciated.
        Rick
        I want to thank all that responded to my post. I have great news. I found my original build sheet and I found it glued to the top front side of my fuel tank above the spare tire carrier. It was glued on and I got it out in a few pieces and was able to tape it back together. After 23 years, it was in pretty good condition. What you need to do is drop the spare, place the lower carrier in the extended position, lay down and look up between the body, rear sway bar and tank and if it's there, you'll see the bottom edge of the sheet. I carefully used a long sharp knife to travel under the glue stripe and break away the paper. You will not be able to get it all but with a needle nose pliers, you can get the rest. Thanks again to all NCRS members for your knowledge. Rick
          • 15601
          #19
          I have no desire to change the subject of your thread, and am glad you found your build sheet. I note you didn't say what kind of tape you used, so I am not being critical of whatever you did. That said...
          Do not use cellophane tape to attach the pieces together. With time cellophane tape will deteriorate, discolor and damage the paper it is attached to. Best practice is to glue the pieces to acid-free rice paper using wheat paste glue. Materials and tips for conservation are available from Light Impressions web site. There may be other sources for paper preservation materials as well.
          • Richard C.
            Infrequent User
            • August 31, 1987
            • 7
            #20
            Thanks Terry for a complete and accurate procedure to keep the build sheet from further deterioration. I did use acid free paper, but I did make the mistake of using the wrong tape. I am going to have it laminated so I think that might help preserve it longer.
            Rick
            • Tom H.
              • December 1, 1993
              • 3440
              #21
              The nice thing about the newer cars is that records exist even if a sheet is destroyed or missing. Like the others mentioned, the museum offers a reprint of your sheet. Glad you had the fun experience of finding a sheet on your car. It is a thrill.
              Tom Hendricks
              Proud Member NCRS #23758
              NCM Founding Member # 1143
                • 15601
                #22
                Lamination, in the proper plastic is currently the best preservation method.
                Having access to "new" documents is a decided advantage to the newer cars, but there is nothing like the thrill of finding THE original paperwork. I was able to compare the assembly line "build sheet" from my 2008 to the museum produced document -- and I couldn't find any difference, but both items were produced at virtually the same time.
                • Peter M.
                  • April 8, 2007
                  • 570
                  #23
                  I was cleaning my spare tire carrier this past weekend in prep for an upcoming Judging Event and as I looked up I spotted the build sheet on the top front side of my fuel tank just above the spare tire carrier. I took a long screw driver and tried to dislodge it, but it started to crumble. As I already have several copies of the build sheet, I decided to leave it where it is. I'll take a couple of photos this week and post them so others can get a visual reference to Rick's discription.
