I have removed the steering column from my 63 and need to know if the bearing which sits between the shaft and the sleeve just outside the firewall should be painted black or is it left natural as I purchased it? Also, there is a clamp that holds a spring (black) and the bearing inside the sleeve which has a natural finish on it. Should it be left that way or also painted black?
Steering Column Bearing -63
