As so many were helpful with the oil problem I posted about yesterday I thought I would give an update. Per advice, I turned the distributor housing so that the flat area was on the passenger side and slightly towards the rear of the engine. Once I then restarted the engine, both sides oiled through the push rods as they are supposed to do. I guess it is better to be lucky than good.
Steve
Steve
