Well is is spring, my 79 has no pedal. I'd like to here the proper way to bleed the brakes.
C3, Brake Bleeding, What's need and how?
Re: C3, Brake Bleeding, What's need and how?
Well, if you have a pressure bleeder put the cap on the master and start at the rear most caliper and crack the bleed valve. I use the old time method and have my Wife pump and Hold the pedal. You may need to tap the caliper with a soft, plastic or rubber hammer to let the bubbles float to the top.- Top
Bleed calipers RR, LR, RF, LF. Don't forget to bleed BOTH bleed screws on rear calipers. It doesn't hurt to tap caliper with a rubber or wooden mallet to shake loose any air bubbles. This is particularly important if you are filling your hydraulic system for the first time.
Joe- Top
