I just ordered the copy cad zinc plating system from Caswell. I've read the archives and see alot of you have had good results with this system.
I am curious about the recommended power supply. I intend initially on doing a few nuts and bolts but I know eventually I'll want to plate larger brackets, linkages, etc.
I'd like opinions on the power supply at the link below or any other power supply recommendations. I'd like to keep the expense down as this is purely for personal (ie. non-commercial) use as I restore my '70 vert.
Thanks for your advice.
